ONN 50” Tv NO PICTURE
When i turn on my tv, the sound from the playstation will work but there is no picture or display. can anyone point me in the right direction. it worked fine the night before last.
Is dit een goede vraag?
Sydney Chandler try another input source. As a matter of fact, try all different ones. You said you can see it with a flashlight but not without? If so, then this is mainly a backlight issue. You’ll have to take the back cover of your TV and have a look at the voltages from your power board to the backlight LED’s as well as the main board. We would need to know your TV’s exact model and possibly see the boards etc. Once you remove the back cover post some good pictures of your boards etc. with your QUESTION. Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
model number ONA50UB19E05 (H19004-JX)
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 5,753
3 opmerkingen
when i put a flashlight to the screen it shows “no signal press input” blah blah blah
door Sydney Chandler
I have a 70 in ONN , you can't see it with a flashlight and there is a volume but cannot see the screen.
I need help
door William Sye
@williamsye depends on your exact model. could be a bad T-con board, bad main board or worst case a bad panel.
door oldturkey03
