Ga door naar hoofdinhoud
please identify resistor on the powerboard
Machine could not be switched on. Replaced the logic board battery, reset the PMU, did all the other tricks recommended on this site. Took the machine to pieces, got to the power board, removed the obviously faulty resistor. Having trouble identifying it since the colour bands are hard to make out, could be a browny green or a greeny brown. It could be 12 Ohms or a smaller number. Does anyone on here know the likely value of this resistor?
ETA: the colours are clear in daylight, not sure which sequence is correct though
Resistor
Powerboard
Is dit een goede vraag?
3 opmerkingen
A picture would be useful as there are a few resistors and capacitors on the power board Voeg afbeeldingen toe aan een bestaande vraag
door
@Folake Shoga - Really need to know where on the board it came from.
door
Thanks guys. I’ll post again after we’ve tried the fix
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Folake Shoga  that looks like a 1K ohm resistor
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Folake Shoga zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 215
