Ga door naar hoofdinhoud
The HP ProBook 450 G2 is a 15.6-inch business laptop marketed toward private and business users.
How do you clean the fan?
I’ve had my laptop for 4 years now and the fan is always ramped up at max, making it very loud and whinny. I have never cleaned it, but I feel like its about time I did, and get to see if that problem goes away. Thoughts?
Is dit een goede vraag?
Score 1
1 Opmerking
remove the bottom cover and start cleaning, you should also replace the arctic grease behind the processor if it is the type to come out. The fan may actually need replaced. Dont use 3 in 1 oil, WD40 will only last a little while.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Samwel Ehr marsha  get the service manual from here Page 75 explains how to get to the fan.
Was dit antwoord nuttig?
Score 6
Voeg je antwoord toe
Samwel Ehr marsha zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 18
Altijd: 914
