Ga door naar hoofdinhoud
This is the 8-inch version of the smaller Fire 7. It includes 1.5 GB of RAM, a faster processor, and an HD display. The Fire HD 8 was released on June 7th, 2017.
20 Vragen Bekijk alle
Can someone please help me locate correct USB charging port?
Can someone please tell me where I can get the correct USB port replacement for this device? I have ordered them off of eBay two separate times now and both times they have been incorrect. If anyone can help me locate the 100% correct charge port I would be very appreciative. It is for the 8th Gen model #L5S83A. Thanks, I have waited too long to fix this tablet already.
Is dit een goede vraag?
1 Opmerking
Do you have a picture of the charger port top and bottom? I can link you a compatible charger port once I see the pictures.
Is this soldered onto the main logic board or on a small daughter board?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ben
Unfortunately that link Jayeff posted is to a USB port for the 7th Gen Fire HD 10 USB port. The correct one you need is this: Fire HD 8 L5S83A 8th gen USB port Also if you do a search for USB ports using that model you will find more of the same incorrect ports which you said you already purchased twice already. This is the only one I found that has the correct port pictured. Looks like they used a motherboard to show them matching side by side.
Hope this helps.
Best
Richard
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Yes, that is the correct model. Thanks so much I have ordered one and am glad someone could point me in right direction!
door
Ben
No problem. Glad I could help out. I notice a lot of sellers listing the wrong USB ports and I mean most or almost all of them.
Richard
door
Voeg je antwoord toe
BEN zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 799
