Ga door naar hoofdinhoud
The larger version of Samsung's flagship phone. Released March 2018.
130 Vragen Bekijk alle
No power on, no charge, black screen
Hey guys! Before nothing, thanks for your help. Have a Samsung Galaxy S9+, these become my hands, and not power on, not charge and no display on screen.
When I plugged the cable into charger port the power consumption is 5 volts and 0,07 amps, but no charge. The battery should be in 3,85 volts but this have 1,54 volts, this point make me think the port charger is broken, but I will like first confirm this.
Someone can help me or will say, ¿how can resolve the points?
Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@stifgs start by following the No Power flowchart.
For this we would need some good pictures of your board to point out components etc.
This maybe a little easier just not as comprehensive
Bottom line is I’d start with a new battery (check your charger!). These guides will help you getting into your phone
Samsung Galaxy S9+
Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thank you very much @oldturkey03 for your full answer, with your tips will go to test each one of the points suggested and with the results come back with new comments.
Really thanks for your interest in help me.
door
Hi @oldturkey03, add images from mainboard, with the new battery, the problem continue.
The button power have continuity in the chasis, but have to make test in the mainboard, but I have not much idea of how make.
However go to make all the step of your guides and will go back to comment.
Thank you very much.
Voeg je antwoord toe
Francis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 32
Altijd: 1,194
