Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Galaxy J2 is een Android-smartphone die in november 2016 werd uitgebracht.
No Sound In Media
I have a Samsung Galaxy J2 Pure. I recently dropped on phone on soup while it was on, screen side facing up. Naturally, I frantically started to wipe it clean. I got the screen cleaned up and proceeded to address the backside of it.
The problem lies where it does sound when I get notifications or it rings. However, it does not have sound when I try to play Youtube or Facebook videos. I tried cleaning up the speaker. It sounds fine in notifications. But absolutely nothing when in any other apps. I restarted my device twice already. “Do Not Disturb” is not on. All volumes are maxed out.
Please help. I cannot afford a new phone or replacing parts right now.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Pull the battery out, and open the device, clean it carefully (all the parts, same for the motherboard). Just leave it off for some minutes and make sure it’s all dry. Then try again to see if it works.. Make sure the contacts are clean and dry.
Was dit antwoord nuttig?
Score 2
You have a broken speaker which means it’s a hardware problem, you can hear notifications because by default the sound they make is made of high-frequency waves, try to play this video on youtube and you’ll see after a certain frequency you’ll start hearing some noise.
Score 2
Voeg je antwoord toe
Salty Pancake zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 2,843
