Ga door naar hoofdinhoud
Radiografisch bestuurbare superbuggy in Formule 1-stijl van Nikko.
Problem with Nikko Landshark
Bought a Nikko landshark without battery. So i connected a other i had lying around an put it to on. IT moved for couple of minutes and the it stuttered and stops. The battery is now recharged and is does not want to move.. I dont see lose wires or anything burned and dont smell anything. Does somebody knows wat the problem can be?
Is dit een goede vraag?
4 opmerkingen
does your battery voltage match the original one?
door
No, its different
door
More or less, please provide us with more information (values).
door
Its a Landshark. I got part removed and disconected battery tray. I place 8.4 battery on the wires and then i was driving with for couple of minutes. Then is stopped and now it does nothing. Nothing is burned as far as i can see. And all wires are good and not lose
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Dennis the original battery was a 6.0V 620mAh so you need to tell us what battery you are putting in. After that you need to use your multimeter and check for the power leads etc. going to the main board. Without the basic information we can only guess.
Apparently the Landshark was known for very poor battery life
Update (09/16/2019)
It's a 6 volt system and you used a 8.4V battery? Check your power board for burned components (you will have to measure the values ) and check your motors to see if they are still working.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Dennis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 25
Altijd: 565
