How do I fix a noisy hp mini 1000?
Noisy hp mini 1000
Is dit een goede vraag?
I just took one of these apart and they are quite easy to take apart. I would open it and inspect it further. This machine has a tiny fan with huge vents that facilitate dust and debris from getting into the fan and its chamber. Get in there with a can of compressed air clean things up. If it's your HD (the only other moving component) then I suggest you back-up and get a new HD as soon as possible. But, I'm leaning to the fan as the culprit for the noise.
Was dit antwoord nuttig?
+1 and just in case you need the service manual, it is available at http://h10032.www1.hp.com/ctg/Manual/c01... and will show you how to deal with the guts of your machine...:-)
A Windows question for you--good answer. +
Thanks guys.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 2,672
3 opmerkingen
It's now 5:22 pm EST. I'll be away from system until after 8:30 pm. Will check upon return.
Jim
door Jim Edwards
Should I decide to remover cover and replace/clearn motor is the availability of a spudger critical? What can be used in its place?
door Jim Edwards
What exactly do you mean by noisy? Like the fan is blowing a lot? Or the hard drive is spinning really fast?
door Jake Devincenzi
