Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
Static noise when calling
Hi,
So I fixed a water damaged iphone 6s,changed screen, battery, charging port and WiFi antenna and removed a shorted cap, the phone works perfect apart from when I make a call the person on the other end can hear static,
Any ideas would be great.
Thanks
Andy
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
test using voice memos. if you can record voice memos with no static sounding then the mics are okay and the fault likely lies with something in the network capabilities. maybe a new antennae but more likely board damage caused by the water
Was dit antwoord nuttig?
Het nuttigste antwoord
Have you tried another earpiece speaker or front camera assembly? If either are liquid damaged that may be causing the problem.
iPhone 6s Vervanving van de naar voren gerichte camera en de sensormodule
iPhone 6s Vervanging van de oorstukspeaker
iPhone 6s Oorstukspeaker Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
10 - 25 minutes
iPhone 6s Naar voren gerichte camera en sensormodule Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
1 - 2 hours
Score 1
2 opmerkingen:
Thanks for your help, I'll give it a go later and let you know.
Andy
door
Hi,
So I removed the front camera and speaker and the static is still there, I did disconnect the charging port and the noise disappeared so I thought was maybe a dodgy port, so tryed another but still the same issue, any more help would be appreciated,
Thanks,
Andy
door
Voeg je antwoord toe
Andy mck zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,120
