Ga door naar hoofdinhoud
Guides and repair information for the LG Exalt VN220. The LG Exalt VN220 (also called the LG Exalt or Exalt LTE) is a flip phone released in 2018.
Is there a repair or replacement for the hinge?
The hinge on one side has broken, and the other side is starting to really crack. Is there a repair or replacement for this?
Is dit een goede vraag?
Score 4
1 Opmerking
do i need to get a new part?
door
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
This would happen to our flip phone, but a much older model. I would buy the same model for parts and swap the pieces that I needed. Usually, I would find my replacements on eBay. If it's out of warranty, that would be the easiest thing to do.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
take off front plastic with blow dryer then take off 5 screws then take out careful the screen and take it out remove the bottom 6 screws need to have to get hinge good in the phone you must have phone open when you click it in
door
Score 1
4 opmerkingen:
What's the best way to get it clicked in?
I feel like I'm breaking it
door
What are you trying to click in?
door
The top and bottom
door
@meinyosele Keep the device open on a flat surface and push in the hinge.
door
You'll want to buy a new lower Hinge, you can buy one on eBay for less than $20 shipped.
Something like this. Under $20
Side note; Make sure to transfer the old metal bracket and metal grounding tab to your new hinge that way you still have oem small parts and a tight snug fitting bracket. The Aftermarket small little parts on the hinges aren't as good as the old small parts so take off those two little parts and transfer them.
Score 1
Yes, there is a website called primephoneusa.com. They have all the parts for this phone.
Check whether the hinge got any rust on it - then spray WD-40, if the hinge has become too tight need to replace with new one.
1 Opmerking:
I'm not sure where you got that idea from, but I would not spray any WD-40 on that device, as small as it is you would just potentially ruin some of the microchips on the PCB board.
There shouldn't be any rust building up on the hinge. If there is any dirt or anything of that sort, you can simply remove that bracket or the little pin hinge and clean it with an alcohol wipe.
Most of the hinge body is plastic, so you shouldn't be having any rust.
Ironically, I never had it where someone had a too tight of a hinge. It's most often where the hinge becomes loose. Let alone you don't want the phone flinging open because of some lubricant. Lastly, who wants to smell that every time you make a phone call.
door
Voeg je antwoord toe
Reed Edwards zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 23
Altijd: 2,316
