Ga door naar hoofdinhoud
Guides and repair information for the LG Exalt VN220. The LG Exalt VN220 (also called the LG Exalt or Exalt LTE) is a flip phone released in 2018.
21 Vragen Bekijk alle
Is there a repair or replacement for the hinge?
The hinge on one side has broken, and the other side is starting to really crack. Is there a repair or replacement for this?
Is dit een goede vraag?
Score 3
1 Opmerking
do i need to get a new part?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
This would happen to our flip phone, but a much older model. I would buy the same model for parts and swap the pieces that I needed. Usually, I would find my replacements on eBay. If it's out of warranty, that would be the easiest thing to do.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
take off front plastic with blow dryer then take off 5 screws then take out careful the screen and take it out remove the bottom 6 screws need to have to get hinge good in the phone you must have phone open when you click it in
door
Voeg je antwoord toe
Reed Edwards zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 32
Altijd: 1,792
