Ga door naar hoofdinhoud
SONOS PLAY 5 is the original, bigger room, bigger sound, all-in-one Sonos music player.
36 Vragen Bekijk alle
I have no power, no light to the speaker, new cord/no go.
the Play 5 worked for the past 4 years. last night was the last. I have no power light, no connection; changed power cord and still nothin. would like to repair before spending the 370.00 on a new one.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @stu4jc ,
Check if the fuse in the player has blown.
This link may be of some help with the fuse. Unknown type of fuse?
Here’s a link to the ifixit Sonos Play 5 guide(s) which should help you in opening the player.
If the fuse is blown then there is always a reason why. Check the motherboard for any obvious problems such as burnt out components or blown capacitors.
If you do spot something and you are unsure post some pictures back here. Here’s how to do this Voeg afbeeldingen toe aan een bestaande vraag
If nothing is evident you may have to get technical with a DMM (digital multimeter) to find the reason.
I tried searching online for a schematic diagram for the player to make life easier, unfortunately with no result. You may have better luck.
If the fuse is blown, order a couple of replacements just in case the new fuse blows as well.
If the new fuse holds and the player is working again, it may have been a case of fuse fatigue.
Good luck with the repair.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
JNS zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 42
Altijd: 2,226
