Ga door naar hoofdinhoud
Laptops made by the Chinese company Huawei.
Can you change/expand the memory on the Huawei Matebook x Pro?
The question is simple as the title. How easy is it to change the memory on the Matebook, and how would one do it if possible?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Don’t know the answer but here’s a video that shows the teardown of the laptop.
It appears that the memory is mounted directly onto the motherboard. (4 chips just below the CPU). The SSD (LITE-ON brand), is on the lower left side when viewing the video .
I don’t think that it would be a very easy task to increase the memory. You’d have to unsolder the chips and then source and replace them with 4 physically and electrically compatible larger capacity chips. Also don’t know what software may have to be changed to detect the increased memory.
Was dit antwoord nuttig?
Score 5
Quantum Leap  looks like Huawei is following others. The memory is soldered to the board. So what you buy is what you get.
Score 3
Voeg je antwoord toe
Quantum Leap zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 50
Altijd: 18,945
