Ga door naar hoofdinhoud
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455 Vragen Bekijk alle
3DS Charging only for a few seconds before promptly stopping.
For details I haven’t use my 3DS for about week or 2 before deciding to play it,
3DS is working fine until I charge it, would only charge for a few seconds and its not even fully charges.
Decided to buy a new charger, same results, change the battery, same results.
Although if I leave the 3DS for a long duration of time take for example 4 hours and proceeds to charge it again, the charging would last more by a minute or more until it stops.
The 3DS recognise that a charger is on it with the battery charging symbol on the top right of the screen but instead of a orange indicator. a blue one appears.
Any idea what’s the problem?
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Your chargers are fine. This is a battery problem.
You can read this guide for replacing your 3DS Battery: Nintendo 3DS Battery Replacement
Here is a replacement battery: Nintendo 3DS Replacement Battery
If you need any help please reply to this answer.
Thanks,
John
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
I haven't actually brought a new battery, although I have two 3DS batteries (one from the console itself and another from a broken one), decided to swap the batteries same result. I can always try to buy a new battery but that will take time on my part.
door
Are you sure both batteries actually work? Is there an swelling on the batteries?
door
I actually tried using the my old broken 3DS to charge, its working on both batteries. The problem probably lies on the charging port of my current 3DS or Power receivers... I could always perhaps use my old 3DS as a source of spare parts but I'm not confident with my soldering skills.
door
Anyway thank you for taking your time on my problem, sir John.
door
I found an article on someone who has had this issue before, which you can find here: My 3ds won't charge anymore
Credit to @lpfaff1 for that answer. Feel free to mark this as answer if this solves your problem.
door
If the battery is fine, check the F2 fuse
Hello, I was having the same issue. I removed the back panel and simply removed the battery, blew off the battery slot, and put it back in. And now it’s working fine. I went for about 2 years without powering it on.
1 Opmerking:
Maybe, but it was working like a week before it just wouldn't turn on. I can't try it cause I already sent it to get repaired. Thank you though. I also had gotten a battery and the charge light stayed on but it still wouldn't turn on.
door
remove sd card and game card and retry. same problem for me and the sd card was at fault.
Voeg je antwoord toe
Robin Oliva zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 115
Altijd: 9,788
