Ga door naar hoofdinhoud
The 2016 version of the Samsung Galaxy A3 budget smartphone (model number: A310F).
59 Vragen Bekijk alle
Why does my phone say its charging when it doesnt?
So yesterday when I went to bed I put my phone at my charging cable next to my bed as normal because it was low on battery. I woke up today checked my phone and the first thing I saw was that my battery percentage didnt go up, it went down. I’ve even tried to use a different outlet and different charging cable and nothing has worked so far.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Bandit  since you already tried a new charging cable, replace the battery and see if that changes things. If it does not, then you may have issues with the charging port or the power management IC on your phone’s motherboard. Let us know what happens once you change the battery.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Bandit zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 26
