Ga door naar hoofdinhoud
De Kia Optima is een middelgrote auto die sinds 2000 door Kia Motors wordt geproduceerd en wereldwijd onder verschillende namen op de markt is gebracht. Auto's van de eerste generatie (2001-2005) werden over het algemeen als Optima verkocht, hoewel de naam Kia Magentis in Europa en Canada werd gebruikt toen de verkoop in die regio's in 2002 begon.
My speedometer and odometer quit working?
As I was driving my speedometer and odometer both quit working is this something computerized or a cable that needs to be replaced?
Is dit een goede vraag?
Score 6
1 Opmerking
I have a 2005 Gulf Stream class A motor home on a Ford V-10 chassis. I went to take the motorhome out and the speedometer doesn't work but the odometer and trip meter do. Can anyone tell me what the problem may be and where the part is located to fix this problem. I did try and replace speed sensor in the rear end but didn't fix the issue I'm sure its something easy to fix but hoping someone else has had this issue
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
I do believe that this is computerized. All instruments are controlled by a computer/ If you have lost the speedometer, more than likely you have a bad speed sensor located in the top of the transmission. You can change yourself by unscrewing it from the transmission trans. It will have 3 wires going to it and 1 wire is brown, 1 is black/white. The only other thing would be a defective instrument cluster. There is also a way to reprogram your cluster, but that again will involve special tools. The best way of getting this evaluated is by having a garage check this with their sensors. Also, you could try a shop like Autozone who offer free engine analyzes. Good Luck to you.
Afbeelding
Was dit antwoord nuttig?
Score 4
try to check battery voltage if alternator overcharges ( max 15.5 volt ) this may be a reason.
Score 2
It is probably going to be your reverse lights switch that was my problem they run off the same fuse my switch was stuck causing the lights to stay on and blow the fuse
Score 1
Voeg je antwoord toe
rufus422000 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 11,308
