Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
My LCD started bleeding for no reason: can I stop it/ fix it?
Today I noticed a tiny spot at the bottom left of my iphone (see img). About 1h later a second expanding stain appeared, top left (see img).. I have a few questions:
1) what could be the reason?
2) any advice to stop it from expanding? Will opening the phone make things worse or may it help?
3) is the only way to fix it an LCD replacement? If so, is this what I need to do? If not, what do I need to do?
Thanks everybody!!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@athanasius
that is a bad LCD. The only way to fix it is by replacing it iPhone 5s scherm vervangen
  1. No idea
  2. it’ll continue. No stopping it.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Cheers for this! Do you know if I can change the lcd without changing the screen? It seems like they only sell the whole screen/LCD thingy together.
By the way, I don’t think the LCD is bad per se, it’s Apple’s original and it lasted several years (phone is old) … I guess these things just happen sometimes (to me at least!)
door
@athanasius it's your LCD that is bad. Unless you have a LCD separator, know how to use it and have done this before I suggest you change the whole display assembly. It'll be very difficult to find and LCD without the digitizer and even more difficult to separate it.
door
Voeg je antwoord toe
Athanasius Pernath zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 826
