Ga door naar hoofdinhoud
Reparatiehandleidingen en informatie voor de Nintendo Switch Joy-Con controllers.
What screwdriver do I need
Can someone link me a screwdriver from the ifixit store that can be used to open up a joycon
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@andrewifix you need a Y00 bit for the backplate iFixit Precision 4 mm Screwdriver Bit Even better if you get the kit so you have all drivers for most common repairs Mako Driver Kit - 64 Precision Bits
iFixit's 4 mm aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top — plus 64 essential precision bits to tackle sneaky security screws. Afbeelding
Product
$39.95
iFixit Precision 4 mm screwdriver bits. Replacement bits for the Pro Tech Toolkit, Mako Driver Kit, and Manta Driver Kit. Afbeelding
Product
$2.99
Was dit antwoord nuttig?
Score 3
1 Opmerking:
For the inside of the Joy-Con, you will also need a Phillips #00: https://eustore.ifixit.com/products/phil...
door
@oldturkey03 gave you some good options, and you hopefully fixed your controller by now, but if you only need a fixed blade screwdriver to open your Joy-Con or Switch, iFixit sells a Tri-point* Y00 Precision Screwdriver
*AKA a Tri-wing screwdriver. It is different from an actual "Tri-wing" Screwdriver. If you are opening a Switch Joy-Con, the screwdriver tip should resemble a Mercedes logo and not a shuriken. These nuances between screw types and more are in this Nintendo Switch screwdriver wiki resource.
Precision fixed blade screwdriver engineered by iFixit. Afbeelding
Product
Tri-point Y00 Screwdriver
$5.99
Score 2
Voeg je antwoord toe
Andrew zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 185
Altijd: 51,415
