Ga door naar hoofdinhoud
De Garmin Nuvi 200 maakt deel uit van de 200-serie GPS-navigatiesystemen van Garmin. Het apparaat werd in mei 2007 uitgebracht. Het wordt geleverd met vooraf geïnstalleerde kaarten van de gehele continentale Verenigde Staten, Hawaï en Puerto Rico. Het is verkrijgbaar in klassiek zilver of roze.
Disabling usb mass storage mode
Recently I plug my USB cable into my computer and now I cannot get USB mass storage mode off my garmin nuvi 200w
Is dit een goede vraag?
Score 5
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
The information provided is from here and explains why it does that. "Garmin Mass Storage Mode devices no longer communicate with a computer with the Garmin Protocol but instead present themselves as a USB mass storage device. When a USB cable is connected between a Garmin Mass Storage Mode GPS device and a computer, the GPS device enters mass storage mode." so you could try the reboot by :
1) Disconnecting the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi should now reboot, but remain in GPS mode!
The only other thing I can think of is that you might require a new cable, if this just came up. Good Luck and I hope this information helps.
Was dit antwoord nuttig?
Score 20
15 opmerkingen:
Thank you much for this fix!!!! It worked!!
Kathleen Marie
door
you are very welcome ;-)
door
Thank you, oldturkey03. Save me $$$.
door
@Mark Koh, you are welcome.
door
worked by pressing and holding it for a few seconds- thank you
door
10 commentaren meer tonen
I have Garmin Nuvi 260w GPS and Have a similar problem I did and fallow all the direction from Steps 1 to 4 as stated above ,GPS started showing running Visual Maps directions ONLY . Great. better than nothing ?
But found Talking Direction is stop working , GPS DONT want to Speech ? . I checked GPS Volume, Sound Settings, i.e. sound is Abled or Disabled, it is abled and also Couple of time switching either way but GPS Don't Give Voice Direction. It Works and Gives Both Sound/Visual Directions together at the same time before performing Fix steps 1 to 4. That means when working all alone on GPS battery and not connected to Car at all> Please advice if you good guys have any solution ?. Abee
1 Opmerking:
Thank you so much. Was ready to throw in the garbage and never buy a garmin again.
door
Voeg je antwoord toe
mona zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 29
Altijd: 41,787
