Ga door naar hoofdinhoud
Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
Can I replace HD?
Recently, I purchased a Mac Mini 2014 A1347 model. I understand the RAM is soldered to the board and is not upgradeable. My next thought is to replace the HD and/or add a second HD.
Currently, I am running Mojave on this computer and haven’t had any problems. I was thinking of at least installing a second drive but I am not sure if I need to buy a HD tray or HD cable.
Update (05/20/2019)
If I didn’t want to replace the main HD, can I add a second drive? If so, do I buy an HD tray or HD cable?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
What is your current drive status?
Mac mini eind 2014 Vervanging van de SSD
Mac mini eind 2014 Vervanging van de harde schijf
UPDATE
As you can see from the guides, adding an SSD is a 15 minute job while replacing the hard drive is a two hour job. Go here to select the size of drive to fit your needs:
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs. Afbeelding
Product
OWC Aura Pro X2 SSD
$239.99
Mac mini Late 2014 SSD Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
15 minutes
Mac mini Late 2014 Harde schijf Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes - 2 hours
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I am not sure what you are asking "current drive status". The computer came with the existing HD. I think it is SATA but I am not sure. The computer is working fine.
door
If you have a hard drive model then you can add the blade SSD. If you add the SSD you can make it the boot drive speeding up the boot and running the apps.
Otherwise your only option is replacing the HD with a larger drive if that's what you want.
door
About your question. This unit is very much upgradeable when it comes to adding bigger or better hard drive. Only issue is its not as easy as just popping out a cover and pulling out the drive. To answer your exact question, this model comes with a regular mechanical drive and can be upgraded to a bigger size or even an SSD. You wont need any adapters or cables.
2 opmerkingen:
I understand what you are saying. However without taking it apart, there appears to a spot below the silver plate to add a second drive. Obviously, I need an HD cable or tray to connect it to the board.
door
Adding a second hard drive is not possible. You can only add a blade SSD drive.
door
Voeg je antwoord toe
jkbmjp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 204
