Ga door naar hoofdinhoud
Tefal Actifry - heteluchtfriteuse. Sinds de lancering in 2006 is deze revolutionaire, veelzijdige friteuse een apparaat waarmee je op economische wijze uiteenlopende maaltijden kunt bereiden, en het is bovendien veiliger en makkelijker te reinigen dan andere friteuses.
Actifry tefal error 6
I get error 6 after few minutes.
Update (01/10/21)
The problem was on the electric circuit .
I have replaced the capacitors and the problem has been resolved!!!!
Is dit een goede vraag?
Score 5
7 opmerkingen
how to repair E5,E6 on fryer tefal
door
Check the HZ may be defrance then specific of machine 50 or 60
door
My actifryer squashes all the food up what would the problem be
door
Please can you advise how to change the capacitors as ours started throwing the err6 fault code today but after 6 or 7 times of it doing it every minute or so it stopped and worked fine again so i imagine its on its last legs or overheating maybe
door
Could you advise where you got the capacitors and how much they cost please
Thanks regards Martyn
door
2 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
There are two capacitors. Change both of them.
Was dit antwoord nuttig?
5 opmerkingen:
Can u put pictures please
door
There are a couple pictures here :
https://www.commentreparer.com/54293/Fri...
door
Where are they..? And what are they?
door
@Adrian Martin Take a look at the link in the second comment here by Eric B; there's a video and picture and places to buy the parts. It's in French, but that's what Google Translate is for.
door
I have got the same error. But the Black Actifry (model serie:025) does not have any capacitors, I discover... But I did get a third capacitor from the supplier, for free ;-)
door
I have replaced both the motor and thermostat and that did not help. I did not have the tool to check circut board but visually all looked fine. At least now after 10 times of disaassembky I know how to do it. I will check the capacitors again.
The official info about contacting electric supply company is absolutely out of the question. I have tried different networks and sockets.
6 opmerkingen:
So how it went? @rogerino
door
@Carlos Garcia quick question. do you have the error 6 on the actifry? Error 6 appears to be related to overheating of the 330nF capacitors on the circuit board. If you have this error post a couple of pictures of your circuit board so we can check things out.
door
Do you mean rhe gray capacitors
door
I have model IH7000 and it gave the same error... now it is OK
door
I am happy that I found a way to change the 334k capacitor & 100uf/35 capacitor error e6
door
1 commentaar meer tonen
Voeg je antwoord toe
Dimitris Louvaris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 99
Altijd: 29,628
