Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
Power button is not working - how to fix it?
Hi,
in iPhone 3GS, the power button is not response.
You press it but no action. The phone felt down to the floor many times.. My question is: What could be the way to fix it? what attached to this button? I know that there is a flex reibbon (Gold cable) that attached to the power button, earphones, volume buttons and it is not easy to fix. That's the only part that affected not working power button? That ribbon?
tnx
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Yes, that ribbon. The Headphone Jack Ribbon Cable #5. A short term fix that sometimes works, is to squeeze in that corner the front screen and back case together (pinching) while pushing the button. When you repair the 3GS, make sure it is OFF before and during all repairs.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
How can I know what is #5 cable? Where are the numbers of these cables? Is there a table of it? thanks
door
And could you please add a link of picture of that part?
door
pintching did not work. So what could be the problem? and what is the solution?:) The vibrate button,headset hole, and the volume button are working.
door
i phone off but on no respons age on celo now on way
2 opmerkingen:
not quite sure what is going on with your phone. Give us more information.
door
iphone 3gs no on now but age on celo others on way
door
Voeg je antwoord toe
Shai zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 28,914
