Ga door naar hoofdinhoud
Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
48 Vragen Bekijk alle
Why is my USB device not recognized?
The system of my computer is Windows 10. When I plugged in my USB hard drive it just doesn’t turn out and shows that "USB device not recognized". I have upgraded all the drivers. They are up to date but still not working. What can I do with it?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi, can you check the USB device from the Disk Management?
Way to check with these steps:
  1. Press Win Logo key + R and then type: Diskmgmt.msc
  2. Find your USB device there.
Give me the feedback, thanks.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
I have followed the suggestion and the device can be found already. Thanks a lot!
door
Hi, if you can find the USB device there in Disk Management, that means the device is still working but corrupted due to some technical reasons. To fix this error, you can try to retrieve the data first from the USB device and then follow the steps with this link to fix: https://www.r-datarecovery.com/usb-devic..., leave me the feedback here, thanks.
door
I've fixed the problem with your suggestion. The software is so convenient to use. Thanks a lot!
door
Het nuttigste antwoord
Try shutting down Windows from the Start Menu.
When shut down unplug the computer for about 5 minutes.
Plug back in and turn on.
Now try plugging in the USB device and see if it is recognised.
Let me know if it works.
Score 1
1 Opmerking:
Thank u for your advice but the problem still remains :(
door
Hi @jityvub
Had you tried on another computer and another USB port?
You mentioned it is a USB hard drive. Do you have model no of it?
When you connect the drive to your computer, I presume it is a mechanical HDD, do you hear any weird sounds coming out from the hard drive? e.g. some tick tick or motor spin and stop abruptly?
Score 1
2 opmerkingen:
It is just a common USB flash disk.I've changed the other USB port and I can find the weird sounds but the error remains. I only have one computer can be used at this stage.
door
no matter what... if data is important, if it can still be access, copy it out.
door
Voeg je antwoord toe
lozemyti zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 12
Altijd: 2,075
