Why do I get "out of memory"?
My camera does not have any images to view (or delete) and I do NOT have a memory card in it, but I get “out of memory” message. Any suggestions? Thank you!
Is dit een goede vraag?
43mb isn't a lot and if it only has 43mb that's probably not for storing pictures as that's a terribly low amount of memory for a camera, u struggle to even find memory cards these days less than 16gb (GB not mb)
Was dit antwoord nuttig?
I have 16g sd card inserted and still saying out of memory
Hi @Beth Douse,
Has it worked OK with an SD Card inserted before?
Have you formatted the new SD Card using the camera’s format option?
Go to Menu > Setup > Format card
Here’s an image taken from the manual that shows how to get to the Setup menus
Also check that the SD card is being detected by the camera when it has been inserted
Here’s how to check. If IN is displayed the card hasn’t been detected
(click on images to enlarge for better viewing)
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 33
Altijd: 2,073
4 opmerkingen
Put a memory card in it???
door c9679
It has an internal memory of 43MB. I wouldn’t think I would need a memory card if it has a internal memory, yes or?
door Judith Johnson
@explegal you will need a memory card. Your 43mb is pretty much taken up y your cameras software. Download your cameras manual from here https://downloadcenter.nikonimglib.com/e... to get a better description of how to insert a memory card etc.
Rep: 1
door oldturkey03
I just put 16g sd card inserted still out of memory
door Beth Douse
