Ga door naar hoofdinhoud
De Scotch model TL901 is een thermische lamineermachine die platte objecten tot 23 cm breed lamineert. Hij beschikt over twee temperatuurinstellingen en lamineert lamineerhoezen tot vijf millimeter dik.
Scotch TL902 laminator assembly instructions
I recently got the scotch laminator tl902..the sheet was jammed so,I opened the machine and removed the jam..But, now unable to assemble it back..Any step by step instructions with pictures would be great help
Is dit een goede vraag?
Score 1
2 opmerkingen
How can I close the input tray on my laminator tl902 when finished and want to put it away?
door
How do you get the insert tray out in the position needed to insert
laminating sheets?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Here’s a link to the ifixit Schotse TL901 demontage guide, which may be of some help
You may be able to reverse the procedure to re-assemble the laminator.
Research online indicates that the only differences between the TL 901 and the TL 902 is that the TL 902 is newer, lighter and has a side handle for easier carrying.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
how do you get the back to open to put pouch in... brand new
door
@ann45280
You don't need to open the back.
You place the item to be laminated into the laminating pouch and then feed it through the machine.
Here's a video that shows how to use it.
door
Here's a picture of how the TL902 roller tension spring is assembled.
Afbeelding
Here's a picture of how the back TL902 older model roller gear is assembled.
Afbeelding
Here's a picture of how the back TL902 newer model roller gear is assembled.
Afbeelding
Here's a picture of how the front TL902 roller gear is assembled.
Afbeelding
Here's a picture of where the TL902 bottom screws go.
Afbeelding
Here's a picture of the one TL902 side screw location.
Afbeelding
If you need pictures of anything else on the TL902, just ask. Cheers!
Score 1
1 Opmerking:
I have a part that is from the other side it’s long and has a circle at the bottom can’t remember where it goes
door
Voeg je antwoord toe
anusharao.p zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 118
Altijd: 4,799
