Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
Vraag afgerond
Proximity sensor troubles (Works sometimes, sometimes not)?
Hi,
i've already read the related answers but that doesn't adress my problem. As i stated, the sensor sometimes switches the screen off during a call sometimes not. Hard reset didn't help. The phone was never dismanteled, but has had a hard life (well i use it a lot).
iOS 4.1 (8B117)
Modem Firmware (Baseband) 06.15.00
jailbroken and unlocked.
Any idea?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
My first guess would be that it's because you have the iPad baseband (6.15.00) installed. Though the dev-team says it's perfectly safe to use, it can cause all kinds of things to go wrong. I would consider looking around on Cydia for a tweek that disables the sensor all-together, or update the phone to a newer version of iOS (If you have saved SHSH blobs) and see if that resolves the problem.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thanks - i reseach into that direction. I'm a bit careful though, because the phone works fine otherwise and i don't want to loose my unlock. +
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 1,531
