Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Weird grey lines on starting screen, in system blue lines.
Hi there, can anyone help me ? I have here friend’s iphone 6 - i replaced him screen around 6 months ago and yesterday he call me that on screen start appearing weird blue lines and when he turn off and then turn on a phone he have weird grey rectangles on the side’s of apple logo - here you have screen https://ctrlv.cz/0Ok5 - and here’s video how it look’s like in system - https://youtu.be/EpWdWK_Lh6M . ( sorry for my english, i hope you can understand it )
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi there!
I would suggest the following:
  1. Disconnect/remove the display.
  2. Inspect the display ribbon cables for any pinches or tears and inspect the connections and contacts on the logic board for any damaged pins.
  3. Use a Q-tip dipped in Isopropyl/Rubbing Alcohol to clear out any debris in the connections and contacts.
  4. Re-secure the display connections and reseat the display.
  5. With the new screen installed, power off the device and let it sit untouched for at least 6 hours.
If this doesn’t help, it is possible that some sort of damage did happen during the repair or pins on the connections on the display or it could simply be a bad display. Hope you are able to figure it out though!
Was dit antwoord nuttig?
Score 1
Probably just a bad LCD but you might be able to reseat the lcd ribbons. Most likely a screen replacement.
There is a chance that the new screen for the iPhone 6 was not replaced properly, and your friend might have done something to dislodge it accidentally.
It might be best to take the iPhone to a shop and have a technician replace the screen.
Voeg je antwoord toe
- Ungeros - zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 116
