Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
5180 Vragen Bekijk alle
There’s a thing on the bottom right of my screen
There’s this graph looking thing that is on the bottom right of my screen and it’s really annoying
Is dit een goede vraag?
Commentaar:
Hi,
Post a close up image of the affected area of the screen.
Here's how to do this. Adding images to an existing question
door
Hi sorry I've been late my PC was broken for I don't know how long but please respond
door
Hi @benjamen50 ,
Would be interested in your opinion/answer on this one.
Cheers
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
That is liquid gone into the backlight diffuser film that is a layer that sits behind the display panel. You’ll need to get the screen replaced to fix this.
I would be worried that liquid may have gotten into the phone. You may want to open it up or take it to a reputable repair shop for internal inspection for liquid damage.
iPhone 6 Screen Replacement
iPhone 6 Screen
iPhone 6 Screen Afbeelding
Product
iPhone 6 Screen
$44.99
Was dit antwoord nuttig?
Score 2
Commentaar:
To be honest I thought it was pressure marks because the spot gets reduced everyday , and there's no way superglue can get into the screen. It also happened when I removed a screen protector when it was stuck on tight.
door
Pressure marks would be yellow bright marks on the screen or white circular pressure marks.
Well since you've mentioned super glue then that would most likely be in the backlight layer of the screen. Be careful when removing screen protectors, some are glued in very strong so take your time taking one off.
door
most likely liquid damage
Voeg je antwoord toe
George ie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 54
