Ga door naar hoofdinhoud
The Dell OptiPlex 755 USFF smallest form factor of OptiPlex 760 series
1 Vragen Bekijk alle
connects to tv but not monitor
i own a optiplex 760 usff , it succesfully connects to tv’s using dvi to hdmi, but not dvi to dvi for my monitor
pls help
Is dit een goede vraag?
7 opmerkingen
Hi @fegelein3290 ,
What is the make and model number of the monitor?
What resolutions does it support?
Have you tried a different DVI cable?
door
Do you know for sure the monitor works? Have you tried switching inputs on the monitor?
door
yes ive tried a lot
door
ive tried on 3 different monitors actually
door
Are you using the same DVI cable among the 3 monitors as well as the TV? What pin style is the DVI cable you are using vs the pin style on your Optiplex vs the DVI pin style of the TV?
door
2 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Based on your responses in this thread, I suspect a DVI-I (male) to DVI-D(Female) may do the trick, the adapter itself is ~$3 online
Was dit antwoord nuttig?
1 Opmerking:
indeed i believe so too
door
If your monitors support HDMI, maybe just keep the connection of DVI to HDMI.
Good luck!
4 opmerkingen:
well thats the thing i have no hdmi monitors only 15pin vga and dvi
door
Does the machine have VGA? Because if so, you can use that connection.
door
my desktop ony has 9 pin vga and dvi
door
ok, so i looked the optiplex has a dvi-i port but the dvi cable and the dvi to hdmi boh are dvi-d
door
Voeg je antwoord toe
Brayden S zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 195
