Ga door naar hoofdinhoud
new battery wont take a charge and iPod wont power up
I replaced battery because my daughter gave me her ipod touch 2nd gen to fix when I recieved it all it did when plug in to wall or computer was show a red bar in the battery and a lighting bolt underneaththe battery. I removed the old battery and replaced with one I bought from ifixit. I plug the cable into the usb and then I got the same red bar in the battery and a lighting bolt in the window then after about 3 minutes I get an apple in the screen but nothing else I have tried to reset I even removed the battery and replaced it again with the same results please any suggestions
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
pellis1309, make sure that your dock connector is clean of debris i.e. lint and that there is no corrosion. Also check the pins and make sure that there is no bent ones. Charge the battery on a wall charger first and see if that works better. it does provide more amperage than your USB port. It is possible that it is stuck in a recover loop and I usually use iReb for those. You can download it from here. Give it a try and see if it kicks it out of recovery. Of course make sure that you double checked, or in your case, triple checked your work. You should also try a new USB cable, just in case... Good Luck
Was dit antwoord nuttig?
Score 2
The same problem seems to be happening to my Ipod and I don't know if I can fix it and recover the data or not. I understand from pellis1309 that changing the battery had not worked so wonder if this is some kind of fault that Ipod 2nd Gen has.
I have tried charging the ipod on a wall charger and on USB but nothing happens. Occasionally when I try to restart the device the same battery sign comes up with a red line on the left and a lighting bolt underneath it. Please advise.
Many thanks.
A
1 Opmerking:
Have you checked your dock port for dirt/debris/bent pins as oldturkey03 suggests? They tend to gather lots of gunk from pockets etc in there and it stops the pins making contact for charging. Use a tooth pick to see if you can remove any visible dirt. Did you replace the battery?
door
Voeg je antwoord toe
pellis1309 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 762
