Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
iPhone does not charge and there is water damage - how to fix?
My iPhone does not charge with most cables (sometimes it works but very rarely) and the battery dies very fast. I send it in because it was still under warranty, but they sent me this picture to show there is water damage (so they can’t repair it).
Is the damage irreversible? Can I fix it myself? Which guides should I follow: change the battery, the docking station, what to do about the water damage?
Thank you!!!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Apple’s water detectors trigger even when there was no liquid but a really high humidity. Basically, it’s their way to say “F you!” and make you buy a new phone or parts that worth just as much as a new phone. Just send it to third-party reputable repair shop and ask them to take a look on your 5C’s USB port, if replacement (that you can make) won’t help or you’re afraid to go deeper (that can also needs to be done in some cases).
And check more cables on your phone or those cables that didn’t work on other devices. If they still don’t work, then it’s just straight bad luck and you got faulty cables. Is they work as usual (it also means that they charge as fast as usual), then you might consider replacing USB port.
About those practices: https://www.youtube.com/watch?v=_XneTBhR...
Instruction on replacing Lightning port: iPhone 5c Lightning Connector Assembly Replacement
Was dit antwoord nuttig?
1 Opmerking:
Thank you for the help!
door
Voeg je antwoord toe
Myrah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 52
