Ga door naar hoofdinhoud
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Vragen Bekijk alle
Why is my trackpad not working properly?
The trackpad on my Macbook suddenly stopped responding properly, when I move my finger the cursor stops intermittently. I found two workarounds that might give some clues:
1) if I apply even just light pressure under the trackpad the cursor moves as it should,
2) it also works if I unplug the power source, ie. in battery mode! (not ideal, since my battery is seriously bad)
Any ideas what might cause this problem?
Is dit een goede vraag?
2 opmerkingen
Thanks guys! As it happens, the trackpad started working again before I could try any of your suggestions. If I had any less experience with computers I would say this is very strange…
Now I have the problem of USB-Midi not working with the power source attached, but that’s off topic…
door
@mholmqv - I would still look at your battery as this sounds like a classic case of a swollen battery.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
It sounds like you have a double whammy here. If your Battery is going it could be pressing on the trackpad from below, often times the battery swells up. I would test it using CoconutBattery Post a snapshot of the main window here so we can see how it looks Voeg afbeeldingen toe aan een bestaande vraag. If needed replace it and you still may need to replace the trackpad and its cable if they got damaged. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement which is the same process for your system. And here’s the battery info MacBook Pro 15" Unibody mid 2010 Vervanging van de batterij
MacBook Pro 15" Unibody Mid 2010 Batterij Afbeelding
Handleiding
Moeilijkheid:
Eenvoudig
10 - 45 minutes
MacBook Pro 15" Unibody Early 2011 Trackpad Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
45 minutes - 2 hours
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Was dit antwoord nuttig?
Score 1
try SMC and PRAM resets. those solve most software related Mac problems. if SMC and PRAM resets don’t work then you might have to replace the trackpad.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad Afbeelding
Product
$59.99
Voeg je antwoord toe
mats.holmqvist zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,788
