Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Wetenschappelijke rekenmachine van Casio. Wereldwijd veelgebruikt door studenten vanwege de uitstekende prijs-kwaliteitverhouding.
Facing Problem on my calculator
My calculator is fully reversed. The number is reversed. Everything is rotated into 90 degree. How can i fix this problem?
Is dit een goede vraag?
Score 4
6 opmerkingen
20°56°its answer plz solve
door
shift button is working only for offing the calculator not for other usages…
door
Has anyone encountered getting the wrong answers when there is a logarithm? Tried to on and off at first and worked but it doesn't work now, also tried resetting but it didn't help.
door
@Anfernee Jinang When you have different symptoms you should ask a new question rather than posting as a comment under an existing question.
door
Also there are only 3 modes left and the rest of the modes just got vanished.
Shift+7 Function is also not working any more.
Please help me
door
1 commentaar meer tonen
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
If you have not tried the reset sequence here it is…
(CLR)
(Setup)
(Yes)
Was dit antwoord nuttig?
Score 1
1 Opmerking:
No.Still it's not working.I already did this work.My full calculator screen is reversed.
door
How's it going I'd like to try to help you fix your device so there's not a factory reset button on the back of it but you could try hitting shift 9 to enter the list then press 3 to reset all and then the equal sign to confirm it then hit the AC button to return it to normal then shift AC to turn it off reboot it see if it works like that then if that doesn't work you may try to take out the battery and getting a paperclip so the positive and negative terminals can reach each other that will help take out some extra electricity let it sit for 5 minutes then replace your battery
3 opmerkingen:
This actually worked for me.. I took of the battery after resetting all and Voila!! it normalized. Thank you for this.
door
Hopefully that will help if not please let me know and I will be happy to continue finding things to help you out
door
It is not working
door
Restart it change the battery
Voeg je antwoord toe
tanni tanni zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 54
Altijd: 9,981
