Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Model A1347. Uitgebracht op 23 oktober 2012. Core i5- of Core i7-processor. Apple Fusion Drive.
Adding second hard drive
My late 2012 Mac mini came with the hard drive installed in the upper bay (the one that is on the 'bottom' when the mini is upside down). I want to install an SSD drive in the other bay but can’t find the proper hard drive mounting pins. Where can I get these?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
T8 TORX HARD DRIVE SCREWS - Apple Mac Mini A1347 Mid 2010 2011 2012
Apple part #922-9584
http://www.powerbookmedic.com/parts/922-...
https://www.ebay.com/itm/T8-TORX-HARD-DR...
Was dit antwoord nuttig?
Score 6
4 opmerkingen:
Thanks very much. Just what I was looking for. :-)
door Deel
@zarkov33 - Do you have all of the other needed parts? Here's the IFIXIT kit with the cable, rubber bushings and screws. It also has the needed tools. Mac mini Dual Drive Kit
door Deel
Thanks Dan,
As I've explained earlier, I am trying to install an SSD in the lower, second drive, bay. This does not necessitate anything other than a SATA cable (which I have) and the 2 mounting pins (which I need). Everything else is unnecessary as it does not require removing the logic board. Thanks for your input. Everyone has been very helpful.
door Deel
@zarkov33 - Just making sure ;-}
door Deel
I suggest you buy this dual drive kit for your Mac mini, it has those pins you need and it comes with the tools needed too.
Installatie van de Mac Mini Late 2012 Dual Hard Drive Kit
All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini. Afbeelding
Product
$29.99
Score 2
4 opmerkingen:
Thanks, but to add a second drive in the lower bay(closest to wifi shield) I don't need to remove the logic board. All I need are the 2 mounting pins.
door Deel
BTW, I already have the proper SATA cable.
door Deel
@zarkov33 The way I suggested is the best way to go thermal-wise. Your drive may not get the proper cooling where you want to put it so I am still suggesting you get that mounting kit so you can mount it correctly.
Plus, I have no idea where you are talking about putting this nor if it will work.
door Deel
I plan on adding the drive to the second drive bay (lower bay). I know it will work because the mini is designed to hold 2 drives. I've done it before.
door Deel
Voeg je antwoord toe
Tony zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 52
Altijd: 1,128
