Red light but no video or audio
I used it for a year without problems but out of nowhere it stopped working. I cleaned it and i have tested all i could on another system that works. But i still cant find out why it wont show video. I got it so it would at-least give me a black screen. so its giving a signal but it still wont give me a picture? I have tried everything i can.
Here is all that i does
Has power and red light
black screen no sound
gives signal (the tv does not show no signal)
all parts work on my other one
Update (10/19/2018)
I got it!
Turn it on without the cartrage
TV should say NO SIGNAL
Put the cartrage in (With the N64 on)
Turn the n64 off then on
should turn on
Update (10/20/2018)
Is dit een goede vraag?
4 opmerkingen
Have you used the video cable on another N64 to isolate the problem to this N64?
I would try cleaning the video terminals with 90% isopropyl alcohol and potentially the cartridge slot and cartridge.
door Jared
I did that and i know it cant be that i have tried new cables and tested parts on my new one. It is sending a signal but its just blank. i know all the removable parts work and also are clean. If it was the terminals it would say NO SIGNAL so its a hardware issue or some kind.
door Bobby gunnels
did you put a cartridge in while OFF then power it on?
door Jordan Fryman
It worked!! And with using the back av leads not hdmi connector thank you!!
door Mitchalez
