Is it possible to have both a SATA III SSD + PCIe SSD?
Hello friends ,
I have a Mac Mini Late 2014 which I upgraded to a SATA III (6.0 Gb/s) SSD Samsung EVO.
I want to know if I can add a PCIe SSD in as well.
Thanks
Is dit een goede vraag?
Hello friends ,
Thanks
If your SATA SSD/HDD is like the SSD I linked below then yes. If your blade SSD is like the blade SSD I linked below then yes. Any other type of SSDHDD/Blade SSD then you will need an external enclosure and to use it as an external startup drive.
Mac mini eind 2014 Vervanging van de harde schijf
[gekoppeld product ontbreekt of is uitgeschakeld: IF123-123]
Product
$30.99
Handleiding
Moeilijkheid:
Gemiddeld
15 minutes
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes - 2 hours
Was dit antwoord nuttig?
To clarify your Mac Mini has two ports one SATA were a standard 2.5" HDD or SSD will work and one Apple custom blade SSD.
It is not able to support a M.2 compliant SSD. So the answer is no you can't use a M.2 SSD in your Mac Mini.
But! You can add in the custom SSD cable and the custom SSD unit (the OWC Aura SSD in the link is also designed to work as well).
Here's a useful reference The Ultimate Guide to Apple’s Proprietary SSDs
Hi,
What is the needed SSD cable for OWC Aura SSD?
Here's the needed cable to add in the PCIe/AHCI SSD Flex cable for solid state drive (SSD)
This is the Guide you'll need to follow: Mac mini Late 2014 PCIe SSD Cable Replacement
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 435
