LCD burnout sign after kept for a few months MBP early 2011
I had a MBP 15” early2011 with a failed GPU just this year and I kept the MBP in the drawer for 2mth,
recently I read on ifix it about there a step to disable the gpu and force to run on the intel building display and once I try to power up the MBP and notice this happen the display turned into such smear pattern and it’s inside the LCD not outside.
Anyone happen to have such issue before? And any solution on this? If the display can be save I might get a 2012 mid logic board and replace the defect 2011 early board.
Is dit een goede vraag?
2 opmerkingen
ngwenyuann post some pictures of what yuor screen shows with your question. Voeg afbeeldingen toe aan een bestaande vraag
Also, did you try an external monitor to see what it displays?
door oldturkey03
I notice the burnout mark on the mbp LCD only. My mbp had a failed gpu I got blue screen with stripe after the gray screen. But the burnout mark remain even during blue screen. This happen after I keep the mbp under my drawer for 2mth since the gpu failed.
door ngwenyuann
