Ga door naar hoofdinhoud
The GoPro Hero3 Black, introducing a new 12MP sensor, was released in 2013 and, at the time, was the highest end GoPro model with 4K UHD video capture. The Hero3 brought a 30% smaller and 25% lighter action camera.
My go pro is not turning on
I dropped my go pro without the case in salt water, I automatically removed the battery and the sim card and kept it in the sun to dry.
After 24h i put the battery back and the red light turned on.
The go pro still not turning on.
How can i solve it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @leahdu
As you know water and electronics and electricity are not a good mix.
The water (especially salt water) causes corrosion and provides circuit paths for the electricity which were not in the camera's operating design and could damage the components.
First do not turn on your camera and then you need to with the camera turned off, remove the battery as soon as possible from the camera to minimize further damage.''
Then you need to dis-assemble the rest of the camera and clean all the affected parts using Isopropyl Alcohol 90%+ (available at most pharmacies), to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is sometimes only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the camera might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your camera. GoPro Hero3+ Black Edition (I couldn’t find a repair guide for your exact model, hopefully this one is close enough to be of some help)
If this process seems too daunting, take your camera to a reputable, professional camera repair service, experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Leah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 287
