Why is t here no sound
There is no sound, it is not muted and volume is turned up to 100%.
Is dit een goede vraag?
@taulton the first thing you want to try is to use different input sources. Try coax, composite and any others. If it still does not work then you will have to check a few things. For that you will have to have some basic hand tools and a meter. Remove the back of your TV and take a good look at the boards. Check for obvious damage, like domed or leaking capacitors. Post some pictures of your boards with your question. That way we can see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that. Follow these instructions to see hwat you find. Let us know what the results are.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 16
Altijd: 295
