Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De eMac was een alles-in-één G4-gebaseerde Mac die werd ontworpen voor de onderwijsmarkt en werd uitgebracht in april 2002. Het was de laatste Mac met een CRT-scherm en werd voor een lage prijs verkocht aan scholen en andere instellingen.
Is my eMac missing a jumper?
I just bought an eMac from a local thrift shop. On the box it said it used European power and came with an Apple European two pronged chord but on the machine itself it says 120V near the serial number and on the bottom access door. When I plug it in to my American outlet and turn it on, nothing happens so I am guessing it is true that it was somehow set to use 220V.
I have been referring to a service manual online, but my computer is a different variation (it is the 1.25 GHz USB 2.0 model). Mine does look the same as the one in the ifixit guide though. I am pretty sure I need a jumper somewhere, but there is only one photo on the ifixit guide of the spot I need to look at, but the spot I need is obscured. Can anyone take a photo of the board (not the logic board, but the huge circuit board under the CRT) where the power cable connects? I’m referring to the spot in the guide where the blue and brown wires from the power socket connect to the board with a white plug. If you’re looking at the eMac from the top front, its to the left of the CRT neck.
Here is what mine looks like:
Afbeelding
Thanks!
Is dit een goede vraag?
Score 2
2 opmerkingen
@nabru50 give us all the numbers from the back of your eMac so we can determine exactly what model you have.
door Deel
Model No: A1002
G4-1.25GHz/256/40/Combo/56K/110V
100-120VAC,3.5A,50-60HZ
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
@nabru50
it will work much better if you post some pictures of what you are looking for. that way we do not need to guess. this is the information I got:
Table 1: Jumper Settings
Voltage / Voltage Jumper /LHR Jumper
110 V /Jumper is on /Jumper is on
220 V /Jumper is off /jumper is on
220 V /Jumper is off /Jumper is off, LHR module installed
with LHR module
Afbeelding
Afbeelding
Was dit antwoord nuttig?
Score 3
12 opmerkingen:
This does look like mine. I am missing the voltage jumper with 2 pins. Any idea where I could get one?
door Deel
@nabru50 P902? I would just temporarily try with a cable with alligator clips. See what happens
door Deel
That did it. It still wouldn't work at first, but I pressed the power button multiple times and it eventually kicks on after 2-3 presses. Thanks!
door Deel
May I please use this thread to ask a question about a US eMac (110V 60Hz) which I want to use in Singapore (220V 50Hz)? If I remove the above-mentioned Voltage jumper, should I be able to plug in directly to 220V?
door Deel
US 110V eMacs do not have LHR installed by default. So, hopefully, I do need to remove the LHR jumper.
door Deel
7 commentaren meer tonen
Voeg je antwoord toe
Phillip Urban zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 622
