My tv has green light coming down
My tv all of the sudden have verdical Green line
Is dit een goede vraag?
macroop if it is a single thin line then it is most likely a TAB error. That is where teh bond between the very thin ribbon cable form the LCD driver board to the LCD panel has failed. Those are non fixable by DIY methods. Sometimes you can remove teh line by putting some pressure on the flat ribbon cable on top of th panel exactly where the line is.
To ensure it is a TAB error take some pictures of what your screen shows and post those with your question. That way we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag
Sometimes some downward pressure applied by some adhesive tape etc. can make them go away for a while at least. If you have trouble identifying the ribbon and Tab just post some more images of what you see on the top of your LCD panel. It should look something like the images I attached.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 365
