Ga door naar hoofdinhoud
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Fuse block schematic and location
Need to know what relays are for
And where they go
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@cburge
there are plenty of relays in multiple different locations. You do want to let us know what it is that you are specifically looking for. Also, let us know the exact year and engine size for your vehicle
Was dit antwoord nuttig?
Score 2
Usually there is a box under the hood or on the left hand side front dash panel that contains the fuse blocks.
Score 1
1 Opmerking:
Your owners manual will tell you if you look through it.
door
Voeg je antwoord toe
Chris Burgess zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,006
