Ga door naar hoofdinhoud
Dell 19" LCD Monitor, charcoal gray in color, released in 2004.
Have a white screen on power up
Moniter was on and all of a sudden went white. Now it is always white no matter what I do. Is it a motherboard issue or something else?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
White screens are usually indicative of a bad hard drive or corrupted boot system.
Was dit antwoord nuttig?
Score 2
mrbruce300  on your monitor this just means that only your backlight is on. You will have to check the video source and see if it is connected etc. If the monitor does not show a menu etc. on startup when disconnected from a video source you most likely have a bad main board.
These monitor had issues with bad caps, so you will have to take a look at the boards and check for an obvious damage. Post some images of the boards with your question so that we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag
Here are the disassembly instructions disassembly.pdf
Score 2
Voeg je antwoord toe
mrbruce300 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 124
