Ga door naar hoofdinhoud
Achtste generatie van de Honda Civic.
headlight its no power
Hi my honda civi 2006 headlight its no power hiw to check the problems
Is dit een goede vraag?
2 opmerkingen
What if they good and still not working?
door
@germanmanuel
What is the year of the vehicle?
Which headlight is not working, left or right or both?
Do the tail lights/parking lights work OK?
A bit more detail about what the problem is will help
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @sherwinlaja ,
Which headlight, left, right or both?
If one headlight:
left headlight - check fuses #13 (high beam) & #17 (low beam) in interior fuse box.
right headlight - check fuses #12 (high beam) & #16 (low beam) in interior fuse box.
If the fuses check out OK use a Voltmeter to see if there is power getting to the headlight in case it is a faulty headlight connector or bulb etc.
If both headlights:
check fuse #4 in engine bay fuse box. If this fuse is blown, it should also affect the power windows as well.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sherwin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 4,450
