Ga door naar hoofdinhoud
Scientific calculator by Casio. Widely used by students world-wide due to its great quality for the low price.
How to repair the display
How to repair the display of a Casio FX-991ES Plus Calculator
Is dit een goede vraag?
Score 9
4 opmerkingen
itIf it’s just that a line may be missing in the display or certain sections of the display is not working,
door
I just sent the CLASSPAD to the main CASIO repair facility, they quoted me all 3 main parts and wanted to charge me replacement cost to put the 3 parts together, I was expecting a software issue or an actual fix, I told them to send it back unrepaired and I will buy the big T.I. Your calculator is less than $30 where I live at the Mall, its popular here for students who have extra money to get this model, its the biggest offered here locally, if you cant find a used unit or the other model the other person suggested then just replace it. I doubt CASIO will send you the screen alone???
door
top line is missed in the display. is it software or hardware?
door
My display screen is divided into 2 parts in fx-991ES plus, how to fix it ?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi @angeltwayana ,
What is the problem with the display?
If it needs replacing unfortunately, I’ve been unable to find a replacement LCD screen. You may have better luck.
Given the cost of a new calculator it may be uneconomically viable to replace the screen even if you could find a replacement part.
If it’s just that a line may be missing in the display or certain sections of the display is not working, you could always try dis-assembling the calculator and inspect the display module connections to the systemboard in case it is a faulty connection that is causing the problem.
Always remove the power source or battery from electronic equipment before starting any repairs etc.
Was dit antwoord nuttig?
Score 7
2 opmerkingen:
Do you by chance know a model name/number for this particular LCD Dot Matrix Display?
door
@loganhowlett
Sorry I don't know.
Sometimes the make and model number on displays can be found on the back of the display itself although maybe not with Casio, judging by what can be seen in this link (see post #4) for a different Casio calculator model
door
I would recommend buying an fx-82es and swapping screens, as they are the exact same screen.
5 opmerkingen:
When I press equal sign then it is showing X10 in screen instead of calculating answer
door
Do not working fx991es my calculator. Problem do not show display.
door
Mera "Fx-991ES plus" Calculator ka display left side par black spot horaha hai kya kare.
door
In my casio fx-991ES plus 2nd edition .
At centre of my screen one line is showing .
How to remove the line .?!
door
আমার ক্যালকুলেটর হলো পেট্রা 991 ইএস প্লাস। এটির ডিসপ্লে বেগুনি রঙের হয়ে গেছে। এটির সমাধান কি
door
Voeg je antwoord toe
Angel Twayana zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 209
Altijd: 26,480
