Ga door naar hoofdinhoud
The Optoma HD20 is a home theater projector that has a 1080p resolution that was released August 2009. Repair of this device requires screwdrivers and prying tools.
How do I reinstall the focal cap?
can not get the focal cap back on, Do push the cap in and turn counter clockwise, how do you line up the cap so you can push it in?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
davepridgeon check this guide Disassembling Optoma HD20 Cover
This is the official disassembly order so it should be in opposite order to reassemble:
1. Rotate Focus Ring by anti-clockwise to the end (as red arrow). Push against
projector lens so as to pull out the Focus Ring.
2. Then take off Focus Ring carefully.
'''Note: When you assemble the Focus Ring, ensure the three card slot (as red circle) stuck in the double-screw bolt ( as blue square) properly, then the focus ring can be well adjusted.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
davepridgeon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 143
