Ga door naar hoofdinhoud
Repair guides and support for Panasonic's Viera line of televisions.
Blinks 7 times then stops then starts blinking again.
My Panasonic Viera has same issue it’s a 50 inch. Model TC-50PS14. Was programming my Fire TV STICK AND RIGHT AT THE end when suddenly POP really loud and it cut off. Tried changing the IsoBar that it was plugged into to another one identical and again when I replugged everything back in it popped again and I unplugged everything quickly. So I get 7 blinks at the off on switch. Blinks 7 times then stops then starts blinking again. Ok do what can it be and estimate the price for fixing it. Thank you. God bless
Is dit een goede vraag?
1 Opmerking
I have a Panasonic TV model No TC-P50S30 that is blinking 7 times, neither the SS or SC board LEDs are lit but the A board light is blinking(bottom rightmost board)
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
IFCJ- SUPPORTER  for your model Panasonic the 7 blink code is for a Driver SOS2 (SC floating voltage area error which can originate on either the SU, SD or SC board.
Of course it is also possible to be a loose board connector, or a mis-seated connector leading to the panel. Check those as well.
You do want to start by removing the back from your TV
This is where your particular boards are located, their names and basically what their function is
Check to see if the LED on the SC and SS boards are lit.
You can of course also add some good images of your boards with your question. That way we can see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that.
Let us know what you find.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Have the same issue, but replaced all 3 boards (SU, SD, SC) and 7 blinks are still there. SC and SS boards have LEDs dimply lit. Any suggestions?
door
@nermall what exact model is your TV?
door
Model is TH-C50HD18
door
I have the same issue (7 blinks, black screen) TH-42PX60U. It used to happen intermittently but start working again after being unplugged for a bit or powered from another wall outlet. Eventually, it became permanent. I have got a new TV but don't want to junk it. So, I opened the back and tried troubleshooting as indicated on several related posts on ifixit. Checking the connectors and hard reset didn't resolve the issue. Disconnecting SD and SU boards (how is this done? I alternatively disconnected the dozen wide orange ribbons on the left or the two different types of connectors each between SD/SU and the SC board. That did not resolve the 7 blink. Disconnecting the three connectors on the right of SC board (coming from SS or other boards on the right and not from SU or SD) did stop the blinking and the light becomes solid. The SS board LED light also remains solid at this point.
All indications are it is the SC board (and possibly SU/SD). Disconnecting just the SC 20 connector stops the blinking (and SS led turns solid green), but disconnecting only SU and SD from SC by and doesn't stop the blinking. I have looked closely at the SC board and cannot find any signs of a damaged part. A resistance check (multimeter grounded at floating screw and at any position on the pins of the connectors (between the SC board and SU/SD boards) suggest a short circuit). Should I just go ahead and get a replacement SC board or is there a way to check and repair the SC board? I can do rudimentary soldering. The board is $30, the TV is $60 probably at this point. Still, a working TV is less electronic waste.
2 opmerkingen:
Ordered the SC board. Keeping fingers crossed.
door
How'd it go? And where did you buy the SC board?
door
Voeg je antwoord toe
IFCJ- SUPPORTER zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 35
Altijd: 1,762
