Ga door naar hoofdinhoud
Repair guides and support for LED, LCD, HD and other Vizio TVs.
Can it be repaired?
Looks like the TV got hit in lower right hand corner. It has a spitter web looking spot and the colored lines running vertically and horizontally all the way across the screen from there.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@robertskelton21
going by your description alone, it sounds like a broken LCD panel. To verify this post some picutres of what the screen looks like with your question. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that.
If it indeed is a broken panel, then it becomes a difficult repair. Vizio use all kinds of different panel manufacturers for their TV’s even within the same model. So, you will have to remove the back of your TV and find the label on the LCD panel. On that you should find the manufacturer and the model number. Use those numbers and do an online search to see if you can find a panel for a prize less than a new TV.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Robert Skelton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 46
