Motor post cover cracked
Can the motor post cover be replaced?
Is dit een goede vraag?
Annuleer
The Cuisinart DLC-8F has only two controls, On and Pulse/Off. Also referred to as a Custom 11 or Deluxe 11.
Rep: 1
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkelHi,
Not quite sure what you are referring to.
Post some close up pictures of what you mean.
Here's how Adding images to an existing question
Are you referring to the stem that holds the blades?
If it is the blade stem then here’s a link to a supplier of the part.
Be aware of the warning given with the part:
“If you are replacing parts for older Cuisinart machines, you may have had discs that each had their own stems.Cuisinart no longer manufactures the discs and stems attached.You must now purchase those two parts separately.“
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 1
Altijd: 57
