Ga door naar hoofdinhoud
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Vragen Bekijk alle
Capacitor knocked off from logic board
Hello guys,
I was doing a battery replacement on my mid-2012 retina MacBook Pro and I was a tad confuddled by how the battery connector removed.
On my third attempt, I managed to knock a fuse (from what I've Googled) off the logic board that was near the connector.
I tried Googling and using schematics to find out what that fuse does and the current / resistance measurement so I can replace the fuse.
I've included a link to which fuse I need knowledge on
Fuse near battery connector
I'd appreciate any help given.
Edit I: It's a capacitor, not a fuse. My Googling sucks (changed title).
Edit II: Additional photos attached of actual motherboard. The capacitor has a light brown strip on it.
Is dit een goede vraag?
3 opmerkingen
What's the logic board number ? It should be marked on the board..reading something like 820-xxxxx
door
I have to double check, but it's manufacture part #: 820-3332-A. This is a 1st generation base 15" rMBP with no upgraded options.
door
I've double checked and that's the correct logic board number.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
That's a not a fuse, it's a capacitor, C6960
a 1UF cap
10%
25V
X5R
in a 603-1 package
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Whoops, sorry about that. I was trying to Googling what it was. Thank you for the information. Would you know what that capacitor does, by any chance?
door
@kevkev it is part of PPVBAT_G3H_CONN circuitry which is your PBus supply & battery charger circuitry.
door
@kevkev I'm not an engineer, don't know what's exactly its purpose but being so small I'd presume is there for smoothing purposes.
door
Awesome. Thanks for the information and your time.
door
Voeg je antwoord toe
Kev K zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 202
